TForce 6100-939 and QPACK questions??
antok86
im new to SFF scene and Hard|Forum
i just built a qpack system wid the Tforce 6100-939 mobo...and i cant seem to find which headers are used to connect to the front AUDIO hook ups in the front of the qpack. If there are headers for the front audio plugs will i still be able to use the sound plugs in the back of my system?? thanks
all i found was on page 12 on the mobo manual it says "this connector will allow user to connect with the front audio output headers on the pc case. It will DISABLE the output on back panel audio connectors." is this disabled if i plug like a headset in the front and enabled again if i unplug it? it would suck to have the front only working and the back plugs not working. i dont mind if they dont work same time...i hope this makes sense
If you plug in the front header or whatever its called then when you plug something in there like headphones it will dissable the back outputs, but as soon as you pull the headphones out the back output will work again, the manual confused me at first also.
