TFORCE 550 , Keep it or dump it?
Shadowhaxor
I picked up the TFORCE 550 + AMD Athlon 64 X2 3600+ Brisbane 1.9GHz combo a few months back and while I haven't had any issues, I wasn't really able to push it overclocking wise. Highest i've gotten is 2.2Ghz. Any higher and it refuses to boot. I'm using two sticks of G.SKILL 240-Pin DDR2 SDRAM DDR2 800 memory as well, has been doing pretty good.
Now my question is has anyone been successful on pushing this board / chip combo, i'm sure everyone's mileage has varied. My main problem though is should I stick it out or drop it for a SLI compatiable / AM2+ board or continue to try and get some OC from this board. And if I go the new mobo route, does anyone have any recommendations on a decent SLI /AM2+ mobo that's good for overclocking?
Thanks in advance!
i have this board with my opteron 1212 and i can do 300FSB. corsair-value select ddr2-667mhz sticks work AWESOME on this board. Better than anything else i've thrown at it (includes high end OCZ, corsairs, g.skill, samsung, mushkin, kingstons). I forgot which bios i am using tho... you can google that!
I have this same board and same CPU.
I can get 2.5Ghz easily on it, have got it as high as 2.9Ghz but it requires a LOT of fine tweaking. Had someone help me with it before, but I flashed the BIOS accidentally and the highest my skill level can get it is 2.5Ghz. I pushed almost 2.6, but FAH refused to run.
You're not gonna get much gains just swapping the board without any other components. No point running SLI with current CPU either. I personally love these boards, built 4-5 identical systems with them last year which are all still in perfect condition and all OC to at least 2.4 with minimal tweaking and no special cooling required (Newegg had some combo special for Brisbane 3600 with that board for something super cheap like $100). If you're gonna upgrade at all, only a full CPU/mobo combo upgrade would be even close to worthwhile. These CPU's are known to top out at 2.4.-2.8 for most people, so spending another $80-$120 on a new board just to MAYBE eek out a tiny more out of a super cheap CPU is entirely not worth it.
If 2.2ghz is somehow limiting you in a particular application, just save up and do a real upgrade. In all honesty going from 2.2 to 2.5 is not very visible anyways except if you time your video rendering/encoding. Both are pretty low end for new games.
i have that cpu with a biostar tforce 7050 board, whcih is an htpc matx board, not really known for oc. but i was able to hit 3ghz using the stock hs/f on this board. so either you are doing something wrong, or the board is a lemon. and since biostar has been making really good oc'ing board for the last 3 years, i would venture to guess that you have some settings wrong, or leaving something out, etc.
