Text shadow on Samsung 245BW
camphor
Hi,
I just got a new Samsung 245BW to use with my laptop. The connection is through VGA. After I set it up, there seems to be a very slight shadow on the right side of any text on a light background and also along the vertical edge of an image. I read an article on another forum which seems to imply that this problem is only with VGA and will go away with DVI - I can't test this because my computer's old and doesn't have a DVI port.
My video card is a Radeon 7500, and I'm using the Omega Driver, version 3.8.205. The LCD is set at its native resolution of 1900x1200. My OS is WinXP Pro. I'm not using ClearType, but I tried turning it on and it doesn't seem to help.
This is the first LCD I ever got - so I'm not sure if it's a setting problem or is it a hardware problem with the display so maybe I should take it back to get another one. Does anyone know about this?
I really appreciate any help!
is there any way you can hook this up to another computer to eliminate the problem being either in the laptop or monitor? its the easiest way i can think of. if possible try both vga and dvi.
I have my 245BW hooked up to my Dell Inspiron 9300 via the DVI cable and I have not noticed any shadowing on text. This is only a temporary setup tho, I am just waiting on my Q6600 G0 from clubit(slow ass shipping).
It is likely either a VGA thing or your graphics card in your laptop not being able to handle the load of the second monitor.
It could also be drivers related, laptops always suffer from lack of good drivers support and usually end up running old drivers or repacks of drivers intended on desktop style graphics cards. I ran into this problem with my laptop with its 6800 Ultra, dell's last drivers set was from nearly 2 years ago.
THRESHIN: I don't really have another computer to test right now (my desktop is even older...) I guess time for a new computer for me. :p Thanks anyways.
Nanan: It's good to know that your 245BW is working fine. So maybe I can just keep this one and see if I plan to get a new computer in a bit. Thanks!
If you install the EasyTune software there is a program in it for sharpening focus particularly on text, it only shows up when you're in VGA mode. On mine I have an "auto" button and by pushing it in VGA mode it sharpens by itself. I noticed the same thing on my new monitor when I hooked up through VGA and the EasyTune did help tremendously to the point it was just about as clear as DVI. That said, hooked up DVI this all goes away and is extremely clear but colors look better through DVI on mine.
I ended up uninstalling EasyTune and MagicColor because one of them was causing a shutdown error when I turn the computer off....I forget which one was causing the problem now though. I'm going to write Samsung and tell them.
Edit:
I'm renaming their software for them :D
It was MagicTunePremium and Natural Color Pro
I tried MagicTune and after some twickling it does seem to be a bit better now. I think I can live with this until I get a new computer. :)
MagicColor is not working well for me - the red just looks way too bright when I have it on the Intelligent Mode. I have it off now and everything looks pretty good.
Thanks for the help!
