cashkennedy
- Apr 25, 2014
I went ahead and setup a windows file server with 2 ssd's for storing hyperv vhd's.
The specifics of the setup are
fileserver: DL380 G6 with 2 Seagate 600 480gb ssd's in raid 1(+0). Drives are most likely running at sata 3.0gb/s speeds because of SAS drives on same controller which is the integrated p410i. Running windows server 2012 r2 file server role. created the ntfs volume on the physical drive (raid volume) then shared it using file shares (no caching selected when creating share). 2 1gb nic's in team.
hyperv hosts: DL380 G5 2x L5330 procs, 8GB RAM. 2 1gb nic's in team.
I then created a windows server 2012 r2 vm and tested the vhd with crystalmark
None of the values are so high that I would assume im maxing out the 2gbps teams, although I'm not sure how to test the max speed 1 direction on the link, because moving a large file is limited by the write speed of the physical drive on the other end, I would need a ssd attached to the hyperv host to write fast enough to test it.
The writes might be being helped by the raid cache (256mb) on the file server, not sure if the raid battery is charged well enough for the server to let the cache kick on.
In the end though, the values seem fairly decent especially for random access... probably fine to run basic servers from.
