Testing sig
{OC'n}Cyborg said:
nope it's not working :D
Don't mess with the n00bie like that. :p
eigna, your sig is working just fine, except I find "(All WindowsUpdates current as of October 12, 2005)" to be a bit of a stretch. ;)
Welcome aboard!
Thanks, also any reason that the size command doesn't work in the signature section? Just want to make the text slightly smaller.
Welcome aboard!
I ment to cut and paste his sig when I said that, but forgot... oops
:eek:
vB code doesn't work in sigs, so you can't re-size, use colors or insert graphics or active links. Less annoying overall that way. Just keep it to 10 lines or less and you'll be fine. :)
Well you could use VB code by doing text here[/SIZE.]
Don't put a "." in it though. I did that so it wouldn't change the size. I don't think it will work though. The admins basically have all the functions in a sig disabled so if your using 56k, the page will load a lot faster and all sigs would practically be the same.
