Testing NetApp Performance?
KapsZ28
What is a good and easy way to test performance to a NetApp? I want to see the IOPS and MBps from a Windows Server 2008 VM running on the NetApp.
You can hit "all in one" to get a huge performance sheet.
If you want random instead of sequential you just hit edit and move the slider.
Your best bet is to test with similar size to your average file that you will be using.
