CoW]8(0);1031294989 said:I'm referring to electrical conducitivity...
CoW]8(0);1031295009 said:What resistance value would ensure I won't have dead parts?
03) What Type of Water Should I Use?
posted by MaxxxRacer: The only coolant I reccomend is distilled water. It has the best cooling properties short of exotic fluids created by 3m (cost upwards of 1000 dollars to fill your system), has relatively low conductivity compared to regular tap water, and is cheap. There is NO need for all of those so-called non-conductive fluids as NONE of them actually are non-conductive. They have moderately higher resistance than distilled water, but will still dammage sensitive electronics.
http://www.xtremesystems.org/forums/showthread.php?t=119699
This is what I was explaining.
So your telling me and anyone else who pops in this thread that using non conductive additives to your loop is not going to damage any components if it leaks?
I'll be more than happy to continue with the links proving otherwise if you'd like![]()
If you have a beef with others over at XS, you may want to consider keeping it there, by the sound of your elitist attitude.
