Testing a computer (Stress Test Programs to make sure hardware is ok)
Format _C:
So I have an old E-Machine I'm fixing for a friend Model W2040 it just looked like a bad windows installation to me (I was getting a short blue screen my Friend did not notice it but I saw the stop error not enough time to see what it said though so I did a format and reinstall using a real XP CD and not the restore Disks so no crap would get put on the computer from E-Machines. So any way I ran memtest and that was fine I just need a Test to do the MB and CPU and see if the Power supply is bad So what programs should I use? Thanks
Specs for this old Computer is as follows
CPU: AMD Athlon™ XP Processor 2000+ (1.667GHz) with QuantiSpeed™ architecture
Operating System: Genuine Microsoft® Windows® XP Home Edition
Monitor Bundle: eMachines® 15" eView™ 15w2 Monitor
(13.8" Viewable, 0.28mm dot pitch)
Chipset: VIA KM 266
Memory: 128MB DDR (PC2100)
Hard Drive: 40GB HDD
Optical Drive: 48x Max. CD-RW Drive; 3.5" 1.44MB FDD
Video: S3 ProSavage8™ integrated (1 AGP slot available for upgrade)
Sound: AC '97 Audio
Network: 10/100Mbps built-in Ethernet
Modem: 56K ITU v.92-ready Fax/Modem
Peripherals: Multimedia Keyboard, 2-Button Wheel Mouse, Amplified Stereo Speakers
Ports/Other: 6 USB 2.0 ports (2 on front), 1 Serial, 1 Parallel, 2 PS/2, Audio In & Out, Mic-In & Head Phone jack on front, 3 PCI slots (2 available)
Dimensions: 7.25"W x 14.125"H x 16"D
Prime95 is a common burn-in/hardware testing program. Can be set to stress either the RAM, CPU, or a mix of both.
How long should I run Prime 95 for? I have been running it for two hours so far with no errors and before that I ran Memtest86 10 Complete loops and it passed
Prime95 for CPU
Memtest for RAM
3DMark0"X" for GPU
If they can make a 24 hr run you will be good. 8 hrs may suffice as well.
Prime and 3DMarks are good apps... and as far as memtest goes, run it for at least 12 hours if not longer... I've seen it run error free for 8~10 hours and suddenly start showing errors, soooo..
If OC'ing, I'd run Prime/Orthos for at least 24 hours. Memtest depends on how much ram you have, but I'd still let it run 24 hours. Yah, I've seen errors pop up in the 25th hour, lol (I just gave it a bit more voltage and it ran 32hours error-free). To test the PSU, use the paperclip trick and a multimeter.
