Test Report: Koolance COV-PMP450A
skinnee
Laing D5 Pump Top
First off, I would like to thank Dean and Tim at Koolance for providing a production sample of the Koolance COV-PMP450A for testing purposes. Dean and Tim were generous enough to send along 2 sets of nozzles/fittings and some additional goodies. A big thank you goes out for their generosity and the opportunity to work with Koolance products.
For the full review, please visit skinnee labs
The Koolance COV-PMP450A is the Acetal version of the Original COV-PMP450A that was made out of aluminum. Aluminum is being removed from the Koolance line up thanks in part to the Liquid Cooling community's obsessant campaign to get all of the companies producing liquid cooling components to cease and desist. Koolance has been listening and is revising the majority of their product line, this is fantastic news for the Liquid Cooling community and I look forward to testing more Koolance products in the future.
The Koolance top fits the Laing D5, which is re-branded by Swiftech (MCP655) and Koolance (PMP450). This top is a full replacement for the stock top that we all have become used to on the D5. Aftermarket tops have become standard for the Laing DDC series, but the D5 is new territory, and I am happy to see Koolance as one of the companies leading the way and making tops for the extremely popular D5.
Fittings/Nozzles pictured are for size comparison only, not included with purchase.
Configuration Options
Performance Test Results (compiled)
For the full test report on each configuration, you will have to visit skinnee labs. These are the compiled results for all configurations, each configuration has a full test report.
Conclusion
Overall the Koolance COV-PMP450A was an excellent test subject, with a variety of inlet and outlet configurations that all perform within a few percentage points of each other. Meaning, no matter what inlet/outlet combination you decide to use, you will maintain good overall performance. Another craving of D5 users has been the need to use fittings over the plastic barbs that are standard on the D5, these stock barbs are a pain to get tubing over and take tubing off, problem solved with the COV-PMP450A. The design and look of the top coincides very well with the original D5 motor, you will not need to hide the pump out of sight any longer. While the performance gains were not stellar, the Top Inlet/Top Outlet configuration had a gain across all speed settings and the gains were in the right area for a "real world" system. The only real gripe I have is the mounting method, the stock mounting bracket cannot be used and if you have already drilled holes in your case you will need to drill at least one more.
