Test for dead mobo
joyntkid
I believe either my mobo or CPU is dead, but i'm not really sure about how to check which one.
The motherboard is the Asus P5W DH Deluxe and CPU is E6750.
All of the sudden when I turned my PC on, the led on the HSF just like kinda flickered, but nothing. The light on the mobo is on, so I wasn't sure if it was the mobo or not. I tried a different power supply, but same result. I took everything out and only had the mobo/cpu and it still wouldn't come on.
I was wondering if I took out my CPU and then tried to turn it on if there was anyway to check and see if it worked. I don't have onboard video except for the little Composite thing.
Any help would be great.
I'm expecting a new 775 board (for my htpc build) like monday, so I can always put the CPU in the board to test, but would like to know before then.
Have you checked your connections, especially the cpu power connection? If everything is connected right, since nearly everything is dead, I would suspect your motherboard or power supply being bad.
Well like I said, I tried a different power supply and still nothing, but I've never used it before.
The little LED light on the motherboard turns on when its plugged up, but nothing more than that.
A motherboard and cpu are coming in by next tuesday, so i'll just swap em out and see which one is the problem.
Check the HSF, sometimes if that's on too tight, it cuts the circuits, ive had it happen a couple times.
Haha, figured it out.
Was neither the mobo or CPU or PSU.
Was just me being a complete idiot. I'm not sure why the original problem occured, but when I switched out the PSUs, I didn't plug in the POWER connector to the case, so pressing the power on was doing absolutely nothing :D
I feel really ashamed admitting to that, but whatever. It's better than having a dead E6750.
Ah, don't sweat it, I've done it a couple times myself. I once even forgot to connect the monitor...to the right computer. Hah, have fun with that E6750 though. :)
Oh, it's been great.
Got it to 3.4 stable easy, but i keep at at 2.6.
It's an encoding monster
