Test Bench\Bed
They used to b all over the net , now i can't find a place that sells them anymore.
It' looks like a metal frame basicly , in a cube shape , giving you 2 shelves to lay ur components on .
Comes dissasembled , anyone know whomakes them @ least?
Thanks.
I would love to have that Senfu Test Bench. I have one question though. If the mobo isn't connected to a case, how do you turn it on? Is there a switch that you can just connect to the power switch pins on the motherboard?
it has a built in power switch, that hooks up to the mobo.
Would it really be hard to make one yourself? I read this from the article... "The DIY Kit is also stackable and expandable (think LEGO)"
