Tesla's motors had a problem with overheating when pushed. When they removed the transmissions it made the situation worse.
ONLY for very small motors with little torque can you achieve such RPMs. For big motors you are limited.
Trust me on this. I deal with big HP PWM electric motors every day attached to fans. I see all kinds of issues. Running a motor at it's max rated RPM is hard on it in the long run and causes them to heat up quickly. It wears out bearings faster, and generates static electricity which can damage the shaft if it's not properly grounded.
Heat = total input power - received mechanical power. Motors are NOT 100% efficient. Well into the 90% range, but not 100%.
No I don't trust you. Electric Motors aren't 100% efficient. But the losses are primarily electrical, not mechanical. Take your 90% EV motor.
10% of 400KW = 40 KW of heat.
10% of 200KW = 20 KW of heat.
RPM isn't the issue, it is the input power. You can run an unloaded EV motor at near it's maximum RPM all day, it won't over heat.
Unload you could probably reach full RPM with less than 10 KW.
10% of 10KW = 1 KW of heat.
Sad that you deal with big PWM motors and don't even understand the fundamentals.
