HardOCP News
[H] News
- Dec 31, 1969
Apparently the Tesla Model S can function as a boat if absolutely need be. Well, maybe not a boat, but it did far better than I thought an electric car would do in this situation.
That, and that it's heavy as lead, so it doesn't start floating in the water.'Consumer Reports': New Tesla has 'underwater mode'
In all seriousness though, isn't this because it doesn't have an intake?
Seems like he was stuck for a few seconds until he took on some water somewhere.That, and that it's heavy as lead, so it doesn't start floating in the water.
Risky. Electric Motors, and Batteries still need vents for cooling. The situation is different for things like well/sump pumps because the water is always there to help cool it. When you can't count on water to cool the motor you work that hard, you have to vent fresh air through it. Batteries get hot during the charge/discharge cycle.
If the guy who did this isn't an engineer at Tesla, he is taking a HUGE risk.
Houston?
...and in a week there might be complaints about stuff not working.
The car is floating in water. The battery and motor weight isn't enough to overcome the buoyancy of the sealed cockpit. The underside is smooth, so minimal thrust can be provided by the wheels turning. This was confirmed by Tesla.
It's got so much torque it can power the wheels through heavy water where normal cars can't to gain the propulsion it requires. You can see the boat like water thrust in the rear view monitor. This car was floating.
Every time they have the slightest issue the internet explodes with negative click bait. Who's anti-Tesla D is getting slobbed for all the negative attention?Seems like Tesla has become the media darlings. Honest question - whose d are the slobbing on to get all this good attention?
The car is liquid cooled.
Do you think maybe the radiators are a bit more effective when wet/submerged?Normally yes, but if it gets super hot the HVAC fans kick in to provide active cooling. The fans dump right under the headlights, so they would be pretty easy to block with high water.
Time to make a Bond film w/a Tesla S.
I can't help but feel that it would be MUCH easier to do with an electric car than with one with an internal combustion engine.
In theory, it should be as simple as waterproofing the car and adding an impeller.
If you do that, add an oxygen tank or two. Mustn't forget the needs of the humans inside.
You know, rain water that falls and splashes on wheels isn't any different than puddle water.
All this talk of dirty water makes me think that some people treat it like a vat of hydrochloric acid.
The batteries are sealed. The electrical connections are made to handle weather and are sealed as well.
The electric motors don't need air to run like a regular engine. There's no gas to burn. Of course it should work.
