Terrible Disk Performance on P6T Deluxe
rflcptr
Since installing a Windows 7 update and restarting last night, my primary hard disk has been chugging along. I've tried uninstalling the update, reseting the CMOS, running in IDE mode, swapping connections, and swapping cables. The boot to the Windows login screen isn't very bad, but the real problem starts as soon as I login. Getting to the desktop is taking upwards of 30 seconds and I can do nothing on it for a few minutes. The drive is accessed constantly during that time.
Anyone else have any similar issue?
you try the hard drive diagnostic tools for your drive to see if its functioning properly?
Sounds like an OS issue to me. Have you waited a few hours of uptime and then tried again? The OS could be optimizing or indexing your files...
It all checked out, for both disks.
I left it on overnight. Programs that normally started up quickly are taking a good deal more time. Even after restarting, the issue persists.
You may want to consider a low level format/write zeros to the drive. This way you can ensure all sectors are clean and not impeding write or read performance. Additionally if you are running overclocked you could be affecting the southbridge. I would recommend you complete the erasure ( via a program like dariks boot and nuke or the hd mfg utility once compelted and if the erasure passes without issues compelte a installation under ACHI. If you are still having issues at that point it could point to an issue with the controller. Also do not forget to install the Chipset and Matrix drivers for the ICH.
Hope this helps and please enjoy the rest of your day.
Also, I've had a seagate drive become mechanically sluggish in the past, but because it _could_ still access all data, the test suites returned fine. If by the drive is being accessed constantly in that time you mean you constantly hear harddrive noises, it tends to be a sign of harddrive wear. See if when you run a self test on the drive you shortly thereafter (and while the test is running) start hearing the same noises if you are hearing noises. If so then you might want to look at getting another drive.
