I have an Antec P160 case, NF7-S, Barton 2500+ with stock heatsink, and two 120mm Enermax adjustable fans at lowest speeds. First of all does system mean case or northbridge? ok, my CPU temps never go over 54c load on a really hot day....the room temperature is about 80-90F. I am using the Abit software that came with my board...it seems to be right on track with the Bios's...only about 1c off. it says my system temps never go over 37c...is this all ok..i mean according to AMD there processers can go up to 70-75c before they shut down.
thanks
thanks
