Temps OK?
Bop
I got my motherboard back and reseated my CPU but I did the dot method instead of spreading it out when I applied the thermal paste. (With a thin layer some spots near the core were missed due to the uneven CPU surface)
Anyways, I have a Scythe Ninja and my P180B case has silent <1000RPM fans(in other words, low airflow). My room is at 72F, sometimes warmer.
With 1.3V and 3.2ghz my CPU is idling at 47C, load at 65-67C under ORTHOS dual core load. I think before it was 44C idle but I cannot recall.
Stock the thing runs 34C idle...
Is it just my OC and its all good or should I be worried?
A bit high for the chip... But that's about standard for a Ninja.
Around 65 would be best, but I really doubt you're doing any harm.
