Temps for Prescott 2.8GHz?
lukepb
Hello,
I was wondering if anyone knew the max temp a Prescott 2.8GHz (775 with HT Support) should be? And what is the average to expect from the stock HSF/cooling solution?
Prescott is running at 56-61* according to BIOS.
450W PSU, 120mm and 80mm case fan.
This is on an ASRock motherboard, which in the past have reported higher then actual readings on other ASRock AMD motherboards (which was corrected with a BIOS update).
Thanks in advance! :)
Stock should be around 40C and full load in the mid 50s.
At least this is what I get for a 3.2 with stock HSF.
Thanks for the reply. I added a second 80mm fan and moved the cables around a bit, which seemed to lower it 3-4*. I have had the system off for nearly six hours and when first booting into BIOS it was already showing 42*? :confused:
