codename47
- Mar 7, 2003
Hey I just put a couple of swiftech water blocks on my IWILL DH800 and according to the bios I'm at 47 degrees IDLE.... which seems a bit high although it is cooler than when I had the retail fan/heatsinks on them. I don't know if this is one of those don't listen to your motherboard kind of things but motherboard monitor isn't compatible with this board so i can't check it using that for real time.... The room it is sitting in does run a little warm so 28-30C on average... my set up runs CPU1- CPU2- pump- radiator-reservoir-CPU1.... I used 1/2in internal diameter tubing... The radiator is a black ice extreme II with two vantec stealth 120mm fans mounted directly to the rad (one fan pushing, one fan pulling, rad is outside the case on the side). I put an additive zerex super coolant but it is diluted with distilled water. I'm pretty sure I screwed down the water blocks enough but I've never done it before and didn't want to tighten too much. from what I could see it was pushing the ceramique out the edges of the processor so I assumed good enough.
The computer runs fine and quite but I just wanted to see if I have something set up wrong... I probably wont change it b/c the system is rock stable... overclocking 2.8Ghz to 3.2Ghz at stock voltages is good enough for me... especially since my ram is 1x corsiar, 1xOCZ, and 2xGeil.... gives me 2GB but not in a pretty way
