Tempest (modded CM MasterCase Maker 5t) by SimpleModz
alexciobanu
Hey guys,
Welcome back to another one of my builds logs! I'm happy to announce my entry into the 2017 Cooler Master CaseMod World Series in the MasterCase Maker 5t. It's a stunning looking case and I'm excited to work on it. I have a few interesting things planned for it, including some layout changes on the inside and a more unique water cooling loop set-up.
I am calling this one Tempest and it will be based on the Tempest spaceship from the new Mass Effect Andromeda game.
I did an overview video of the case as well as talked a bit about the mods where you can get a better idea of what I'm going to do in this case.
Check it out below:
SPECS:
Case - Cooler Master MasterCase Maker 5t
CPU - Intel TBC
MB - ASUS Rampage V Extreme
RAM - 8 x 4GB Crucial Ballistix Elite 3000MHz DDR4
GPU - NVIDIA TBC
SSD - 2 x 275GB Crucial MX300
HDD - Seagate TBC
PSU - Cooler Master V1000
Custom cables & lighting - CableMod
Water Cooling - Bitspower
I'll start it off with some photos of the gorgeous case:
Thanks for checking it out and stay tuned for more
Cheers,
Alex
Hey guys,
Progress has been slow with this one however I thought to give you guys at least some content as I'm still trying to figure out how to tackle this build :)
The case is fully stripped at the moment, ready to be cut into! And by the look of things, there will be a lot of cutting :p
Stay tuned!
Cheers,
Alex
Not much real progress on the build with this update unfortunately. It's a bit hard to keep up with the 3 builds I'm working on at the moment.
Here are the new Cooler Master RGB fans.
Stay tuned for more!
Cheers,
Alex
Hey guys,
Sorry for the lack of updates on this build but unfortunately that's what happens when you're working on 3 case mods at the same time and they all have to be finished at the same time. Plus I've got my full time job on top of that. Been super busy lately.
What I'm gonna do however is focus on getting this build log ready and finishing this build as it has to be done and submitted for the Cooler Master Case Mod World Series by the 3rd of May.
So here is the progress that I've made so far. The PSU has been mounted in it's new location, I have a new motherboard tray that is mounted over the existing one to maintain the case rigidity, the back panel has been completely cut out and a new panel installed that has a 240 radiator mount and the I/O is in the top.
I also have the extra 'top' exterior panel mounted on the back. There is also a cut out in the mid-tray section with a piece of acrylic mounted over it. This is for the pass-through fittings later.
You will also see an acrylic panel in the bottom and a piece on the back.
I hope that all makes sense but I'll have a video in the end explaining it all and showing more of the actual progress for those interested.
I have to give a huge shout out to Corey from Imfaceroll Gaming for the help in cutting the aluminium panels on his CNC machine. Otherwise I don't know how I would have had time to get this done for the submission date.
Also thanks to Justin from Metalicacid for the tips on how to brush my aluminium panels. I think minus some of the deeper scratches they all came out really good. Most of that will be covered anyways.
So here are the photos guys!
I forgot to mention the cut out in the front panel as well.
Hope you guys enjoy the progress so far and stay tuned, there will be a lot more photos to come!
Cheers,
Alex
Hey guys,
Here's some quick pics of the motherboard going in. I know the Rampage V Extreme is a bit old now however it will match the theme perfectly :)
Also, huge shout out to Mwave Australia for sending over a 6850K for the build!
Time to get some water blocks on :D
Thanks for checking it out!
Cheers,
Alex
I don't think I've done this many water blocks on a motherboard before, and GPUs will be added as well of course :p
I'm excited to pipe it all up!
I decided not to use the monoblock cover that comes with this Bitspower kit and I'll connect everything separately. It will work better with the look I am going for.
Cheers,
Alex
Hey guys,
Here's some further progress of the way I mounted the reservoir/s and also some close-ups of the combo. You can also get a better look at the new back panel and the cut out in the mid section.
You can see the vinyl design for the fans and if you saw earlier in the build log, I showed the new CM RGB fans... well I ended up changing these to the red LED JetFlos to make things easier with the cabling; the RGB fans were adding one extra cable per fan and I would only want to have them on red for this build anyway so I didn't make sense to add the extra cables.
Thanks for checking it out and stay tuned as I wrap up this build log.
Cheers,
Alex
Alright, motherboard is in, the reservoir is in, some of the tubes are in and the graphics cards have waterblocks on. I'm using reference 980s but hey it's not about the latest hardware with this build.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
Okay guys, the build is actually finished at this time however I haven't had time to take final photos yet so I will share the last update!
Thanks for checking it out and stay tuned for final photos!
Cheers,
Alex
Okay guys here we go, final photos!
Here is my Tempest, Mass Effect inspired build!
What I wanted out of this is a custom system that is very well put together and also engineered quite well, taking advantage of every single inch inside the Maker 5t chassis. That and a very nice and complex yet clean looking water cooling loop. The idea was that the build would look like a spaceship engine or a reactor of some sorts, something that would belong in the world of Mass Effect! I'm pretty happy with the finished result!
Huge thanks to the amazing companies that support me in achieving my dreams!
SPECS:
CPU - Intel Core i7 6850K
RAM - 4 x 4GB Kingston HyperX Predator 3000MHz DDR4
GPU - 2 x NVIDIA GeForce GTX 980
SSD - 2 x 240GB HyperX Savage
HDD - 2 x 2TB Seagate Firecuda
Fans - 8 x Cooler Master JetFlo - red LED
Custom water cooling - Bitspower
