Temperatures not showing up correctly
sparkomatic
Ok im running a P4 2.4 clocked to 2.709 with TT disabled and a Thermaltake Spark 7+ Hsf all loaded on a cheap ass ASRock P4 combo mobo (my old board died and it was the only socket 478 board I could find locally, and I wasnt waiting)
OK this thing has been stable as hell for months, but its always concerned me that my cpu temp shows up as an average of 23-24*C and I know thats far from correct
Does anyone have any suggestions of what temperature monitoring solution to use
I have tried PC Wizard, MBM, Speedfan, and some other odd ones and all of them show my cpu temp in the 20's
Please help me with my dillema
Sounds like a bunk temp sensor. Nothing you can really do about it, but considering the minimal oc you have, I wouldn't really worry too much about the temps. You could try flashing to a different/newer bios to see if that was an issue that needed to be fixed.
