Temperature Probe For Fan Speed
Outie
Hey Guys heres Outie again, :p
Hey I am using the Swiftech (MCX462-V) with an 80mm MadDawg (MD-TTF-DB-A1357 -TurboFlow Dual Ball bearing High Speed Fan - Auto Temp. sensor/Man Speed Adj) for the heat sink fan. Here are the specs for the fan:
Dimensions 80 mm x 80 mm x 25 mm
Max. Air Flow 20 CFM @ 1300 RPM
75 CFM @ 4800 RPM
Noise 17 dB @ 1300 RPM
48 dB @ 4800 RPM
Air Pressure 1.45 mm H2O at 1300 RPM
8.43 mm H2O at 4800 RPM
Rated Voltage 12V DC
Started Voltage 6V DC
Rated Current 0.04A ~ 0.50A
Bearing Type Dual Ball Bearing
Power Input 2.40W ~ 8.40W
MTBF 50,000 Hours
Connector 3-Pin
Weight 80 g
Should i leave it a max or attach the temp probe to it and let it cycle up and down when needed and if/when i use the temp probe where should i attach it?
Outie
