Temperature of Atom CPU
fender
I have an N270 in a Lenovo S10 an I'm wondering which application gives the correct CPU temp.
Real Temp says 37º C
Hardware Monitor says 52º C
Core Temp says 72º C
Any ideas?
What version of realtemp you have? Touch that heatsink and see if you can keep your hand there for a while :)
Going with the higher one, you can attempt to create a safer environment for your Processor.
or shat your pants.
The temp of the Atom in my Dell Mini 9 which is fanless reads about 42 C idle and around 54 C under load. Maybe this will help.
The N270 has a TDP of 2.5W, so I highly doubt it's running at 72C. I'd say the temperature reported by Real Temp is probably the right one.
Yeah 72 C is ridiculously high for an Atom. The mechanics of that are probably pretty damn near impossible...
Nothing impossible about it. Ever try sticking a Little Falls 2 in a case with no fans? That northbridge heats everything else up so bad you cannot touch the heatsink without it causing pain.
