Morrisvald
- Oct 8, 2009
Hi!
I just flashed the BIOS from the stock revision to the latest revision "1702", and notice that the CPU temperature has increased a bit. It used to idle at 43C, but is now up to 51C.
I also ran the 3dmark vantage , after the stress-test , the highest reading of the cpu temperature was 71C isnt that a bit much for an core i7 860? pc probe is starting the alarm after 60C. Is it possible that the new bios increased the temperature?
I loaded everything in optimized defaults, and changed the fan profile to standard, (the same setting I had before the bios flash). I not 100% sure about the configuration because someone else build the computer. Is there something I have to adjust in the settings of the bios? Or could I just runt with the optimized default settings?
my computer spec:
Chassi: 1 x NZXT Crafted Series Apollo, Mid Tower, 5x5.25" / 1x3.5" Ext / 4x3.5" Int, 3x120mm (2 inkl.), 2USB / FireWire
Zalman ZM750 HP Power Supply 750W
ASUS P7P55D PRO, Intel P55 Express, 4DDR3 / 2PCI / 2PCIe x1 / 3PCIe x16 / 7SATA / 1IDE / 1eSATA, FireWire / 8USB / GBLAN / HD-Audio, ATX, LGA1156
Intel CPU Intel Quad Core i7 860 (2.8GHz) Socket-1156 1333MHz 8MB Cache 64bit 95W Lynnfield B1 Boxed
DDR3: 1 x Corsair XMS3 DDR3 1600MHz 4GB CL8
Seagate Barracuda 7200.12 1TB
my computer spec:
