VanGoghComplex
- Apr 5, 2016
Quick profile of my system:
Alphacool Laing DDC310
to
Gigabyte GTX 1080 Waterforce WB (full cover water block)
to
Swiftech MCR140-QP
to
Heatkiller IV Basic Intel Acetal
to
Swiftech MCR240-QP
back to res, back to pump.
I'm running my i5-7600k with a 4.6GHz XMP profile and my 1080 with a +75 core and +600vram offset at stock voltages.
This is all in an Enthoo Evolv ATX.
My system, under heavy consistent load (Titanfall 2, for example) reaches the low to mid 60s on the CPU after an hour or so of play. That seems high to me.
I'm not sure where to move from here to lower those temps, but I've got a few ideas.
If I'm creative, I can add 2.140mm of 30mm rad to the front of the chassis. That is about as much radiator as I can cram into the system.
The other idea is to open up the Evolv with one or more of the various mods available on the market for improving airflow, like vented front and top covers.
Finally, I'm not sure if a DDC is really the best option for this setup. I've got one of the lowest restriction CPU blocks on the market, and understand GPU full cover blocks to be generally not restrictive. I'm wondering if a D5 would help things.
Where do you guys think the deficiency lies?
to
to
Swiftech MCR140-QP
to
to
Swiftech MCR240-QP
