Alright so Ive had my watercooling setup for a few weeks now and want to see if temps are normal. To me they seem a little high but I will see what the experts here have to say.
FYI, this isnt my first water cooling rig by any stretch, but this one has me curious. Pic of loop below post.
Hardware:
AMD PII 965 BE @ 4.1ghz / 1.385 vcore
16gb Patriot Xtreme 1866mhz DDR3 (@ 1333 for AMD Memory controller safety)
ASUS Crosshair V Formula ROG Motherboard
EVGA GTX580 772mhz OCd to 900mhz @ 1.1v (Runs stock speed/voltage in 2D mode)
Watercooling:
EK 4.0 Pump
EK GTX580 Full Cover Copper/Acetal Block
XSPC Raystorm AMD CPU Block
Swiftech MCR360 Radiator
Swiftech Microres v2
1/2ID x 3/4OD Tubing
EK Fluid
Yate Loon Low Speed Fans (They still move a good amount of air, temps dont seem to change with my medium speed fans either, FYI)
Loop:
Pump>Radiator>CPU>GPU>Res>Pump
Temps Idle (Ambient is 73*f)
CPU: 36*c
Core1-4: 32-33*c (+/- 1*c)
GPU: 27*c-33*c
(Can anyone tell me why the GPU seems to fluctuate 6*c when idle and a steady ambient temp of 73*f? My space is very well conditioned and is a constant temp. I cant find any pattern of it, and when temps vs usage is monitored in Afterburner, the temps will rise slightly to 31-33'ish with 0% load all across the board)
Temps Load (Ambient is 73*f):
CPU: 50*c (Prime 95 Blend)
Core1-4: 48*c
GPU: 57*c (Played 3 hours of BF3 with Ultra settings and temps stayed around 52-54*c. Load was tested in 3DMark11)
So... with this overclocking i am doing, and the voltage bump, do these temps see acceptable on a 3x120rad and this setup? Im thinking of adding another 240 rad for my peace of mind. Sure, these temps are much cooler than air cooling, however was still $450, so I want to make sure nothing seems amiss.
Hardware:
Watercooling:
EK 4.0 Pump
EK Fluid
Loop:
CPU: 36*c
GPU: 27*c-33*c
Core1-4: 48*c
