Temperature and Humidity reader device for server room?
badtz
Greetings,
Does anyone have any suggestions on a simple temperature/humidity reader-type device to be put in a server room?
the room only contains one server. Nothing super fancy is needed, just a very simplistic device.
The only device I've found is this one .....
http://practsol.com/thum.htm
the extra features (emailing, etc.) are cool, but not absolutely necessary ......
any suggestions?
The digital termostat that runs the AC in my server room provides both temp and humidity data.
I forget the brand, but it came with the 5 ton AC unit we put in to keep our 9 servers + communications rack cool here in Phoenix. (overkill is good)
==>Lazn
You could get a digital hygrometer from any cigar shop for about $20 as long as you don't need it to interface with a computer. It gives you temp and humidity, some will also give you min/max temp/humidity readings as well.
