Temp update-mini H2O rig
TheRapture
Ok, I was getting 52c load temps from my chip....I ended up being able to drop my voltage down to 1.35v in the BIOS (reports as 1.4 via Abit EQ) and my temps dropped nicely. Now, in the middle of the day (hottest) I am seeing a max of 48c running the cpu's at 2.4ghz. At night I get 46c load temps after it cools down a bit...
This is using a tiny copper radiator, slow Hydor L25 pump, and a Vantec Stealth 92mm sucking through the rad. Radiator is only 4"x4"x2" :p
http://img375.imageshack.us/my.php?image=newrig0014gx.jpg
http://img375.imageshack.us/my.php?image=newrig0067df.jpg
You really don't need that long of a tube on the T-line, otherwise nice, simple setup, and pretty good temps for a speedy dual core on one tiny tiny rad :p
