Temp sensors on ultra D
Converge
Im running speedfan 4.24 and im just trying to figure out which temp/sensor goes with what.
These are listed:
Temp 1 - IT8712F - temp 1 - 32c - ISA - $290
Temp 2 - IT8712F - temp 2 - 32c - ISA - $290
Temp 3 - IT8712F - temp 3 - 37c - ISA - $290
*Chip set, HDD temps after
Last listing: Temp 1 - ACPI - Temp 1 - 36c - ISA - $0
Anyone know what goes for what? Im thinking the cpu is the last one, 36c sounds about right. Not sure though. Anyone know?
EDIT: I played some farcry for a bit as a test and the only temp that really went up was the first one. Went from 32c idle to 38c. Damn...bios was telling me that my cpu idles at 37-38c. I know bios temps are usually high, but i didnt think they would be THAT high.
