It does not, but RAM doesn't get all that hot. Don't worry about it. When overclocking, we all push our RAM to its limits, and barely anyone has a temp sensor for RAM. If they do, it's probably a custom solution.
well, it depends on the ram you have and how much voltage you are planning on throwing through it. as far as value ram goes, the limit is usually around 2.8V's as a safe ammount. i just got my Patriot PC4000, and to start with i threw 2.7V's at it cause at htt278 at a 5:6 divider its running ddr 463 speeds, at 2.5-3-3-10 timings.
