I am thinking these temps are pretty high for the HSF and fan i have on my processor. At idle I sit around 42C and at load 55C. My room temp is around 25-30C it heats up quick when the air goes off. Run a p4 3ghz not overlcocked or anything with a SP-94 and a Panaflo 90mm. I see other peoples temps seam to be alot cooler. Airflow in my case is pretty good, a 120mm fan in and 120mm fan out in the new tsunami case. Any suggestions? I used As5 when i mounted the hsf. Maybe I didn't do a good enough job. Any suggestions welcome, thanks much. Also those temps are on an Abit - IC-7 board so they could be somewhat high.
