Temp problem with my Si-97 and 2500+
Moloch
I'm running it at 2200mhz atm, and the load temp is a wopping 55C.
It's better than it was before I remounted+ re applied ASC(about same temp at stock speed) but still not what I expected.
I did have great difficulty mounting the HSF, the retaining clip was a SOB to get hooked on right, I believe I placed the HSF on the cpu, and the moved it cuz I couldn't get it mounted right.
Fan is the panaflow 92MM "high output" fan.
Is there some trick to mounting this HSF?
I have the processor and HS you speak of. I'm not overclocked though, just running stock at 1.8. My fan is a 92mm Nexus @ 12v. At idle I get about 40C - 44C with a 34C case temp and mmmm maybe 21-22C ambient, so that's pretty warm itself.. I just put a real thin layer of the AS Ceramique on the core and then put the heat sink on. I found it helps a lot to put the heatsink on with the mobo out of the case, it makes it a lot easier to clamp down the clamp (use a wide flat head screw driver), and then with that assembled put the mobo back in the case.
I would guess overclocked I would get around the same temps you do if I were in a warm room. It's all relative, though. If your computer is in a warm room, your case airflow isnt too great, or you're running quiet, I wouldn't worry about that 55C at all.
Reseated again today.
Much better temps now.
at 2.2ghz. 1.8V, idling at 44C, with my cpu fan running at 2000rpm instead of 3000 rpm.
Using speed fan :cool:
Letting it spin at 100% for a while, see how cool it gets.
42C so far.
Thats good imo, how much did temp drops after a week, with powering pc off like artic silver wants you to?
Can't say, didnt really pay attention. I would guess you'd see a one to two degree drop. But it's quiet and not burning a hole in my floor. My fan's only at 1600 rpm max, and i only have a 120mm Nexus exhaust at 7v and an Antec sl350s psu with 80mm quiet fan.
anything's possilbe... are you using the temps your mobo gave you, or motherboard monitor 5? My temps given were all from MBM5
Temps mobo gave you - in your bios or maybe a utility it has. Your temps look fine to me. at stock speeds, MBM says I peak at 50 at load, and idle I sit around 40-44, depending on the outside environment. And this is all going for low-noise here (so less airflow), so I expect my temps to be higher. Your temps are lower than mine, and you're pushing a lot more voltage through yours. What are your load temps? I'd say if at load you're around 50C or less, you're doing good.
Edit: I wouldnt even worry about your peak load temps unless they hit the 60's.
