First things first. I know its not the thermal paste. I have put together enough computers to know how to put it on, and besides, i tried reseating the heatsink countless times.
So i jumped from AMD to I7 and the temps seem to be high. i hit 83c at load on a I7 930@3.8ghz with hyperthreading off, and at stock voltage. I bought the cpu off of hardforum, and it came lapped. I have narrowed it down to between the two following choices.
A) My case. It's a Antec 1200 case that i bought within the first few weeks of it's release. I honestly think it's this, because quite frankly, i haven't taken as much care of it as i probably should have.
B) My heatsink. Noctua NH-D14. While taking it off my AMD setup, one of the screws with the springs on it came out of the bracket. Might not seem like a big deal, and i don't know if it is, but the heatsink seemed to go on nicely when i just stuck the screw back in there.
I think it's the case because i recently helped my brother build i i7 920 rig and he got 4 ghz at the same voltage as my cpu, with hyperthreading on, with a hyper 212+ and a HAF 932 case. Same motherboard as mine. I thought i'd see what some of you on here have to say before i decide on what to buy. If i get more votes for the case being at fault, ill either get a Phantom, or wait til the Corsair H100 comes out and stick it in there....if its the heatsink, again, ill probably just get a Corsair H100.
