RealMentalCase said:i don't know ask the [H] pros
i hope it helped !
i need a few of them myself but i couldn't remember where the site was
that had cheap ones![]()
Erasmus354 said:you can make your own temperature probe with a t-line and some hot glue or something, although you want to be careful cause you can short out some probes if you actually stick them in the water.
zer0signal667 said:A quick dip in epoxy will fix that.
Is this going to be a permanent installation, or just a test to see how well the radiator is performing? If it's not going to be permanent, there are cheaper ways to do it.
OPUS1 said:Well I always like cheep so temporary.![]()
I think I see where your going with this. So I just need to ghetto something, no?zer0signal667 said:Do you already own a temp probe or thermometer?
OPUS1 said:I think I see where your going with this. So I just need to ghetto something, no?
