Quick advice question - my Corsair HX620's fan is failing, and since it's still under warranty I figured I'd RMA it rather than try to replace the fan myself. I have an older OCZ Powerstream 520, and am concerned that it may not be enough for what I'm running, but I'm bad at the math on what I need.
Currently running the following:
Q6600 (not overclocked)
IP35 board
ATI 6950 (flashed to 6970)
3x120 yate loons on radiator
2x140 case fans (stock with 800D)
2x raptors
2x WD's in raid
1x AquaExtreme 50z-DC12 pump
The primary thing I'm concerned with is the GPU, as it says min 500w PSU and I"m barely over that with the backup. Will this thing be enough for a week or two of use?
IP35 board
2x raptors
2x WD's in raid
