temp plastic barb fittings?
AP2
can anyone recommend any cheap plastic barb fittings? I just need to test my new loop and all I have is rigid fittings at the moment.
You can probably get some from your local hardware store.
Or you can get cheap metal ones too, bought a six pack for $11 on ebay.
Yeah, ace has'em (here, anyway), and hd/lowe's, too, I think. P-pcs and a few other watercooling shops stock them, too.
6 pack is like $7CAN on amazon or home despot should have em.(metal ones)
Check in the loose screws/bindings section of any reputable hardware store. You can usually buy them by the piece.
Or if you are talking about G1/4 barbs to mount to blocks and whatnot, you can find the cheap chinese junk ones on Amazon in packs of six for less than 10$.
Not something I would use for long term use but good for leak/component tests.
Reactions: AP2
