Temp help
Rydawg5143
I just put the system together in my sig. Everythign is working fine. Coretemp and everst show by cpu temps at 45-51 when they are idle. Is this normal. This is the 1st intel dual core i have ever had.
yep sounds about right, although those temps can go lower.
So what temp should i start worrying. I'm coming from a amd 64 x2 4000+ where idle temps where 25 w/ stock cooler.
i personally wouldn't go higher than 60º Celsius at full load. But then again that is just me.
and i have a Quad Core so u do the math ;)
don't worry If the temps go ultra high, the cpu would shutdown itself, that setting is embedded on the cpu itself it doesn't go thru the BIOS if i remember correctly. So u would have two fail safe mechanisms
So is there a guide or something to lower these temps?
you can check in the Overclocking and Cooling Subforum, lots of info there.
but basically, a big heatsink fan is needed, good air flow, good contact between the cpu and heatsink, good thermal paste, etc.
Or get a bolt thru kit, can't recall which one, seeing as the pin mount system that the HDT-S963 sometimes doesn't offer great contact b/w the heatsink and the CPU.
