Temp Gauge Program?
I was wondering where I could find a program to monitor the video card temperatures of my 9800 pro when I am using ATI Tool. Also if anyone knows some temps that are dangerous please lemme know, thanks!
If it has the R350 core, then it wont have one. An R360 cored one will, though.
FYI, R350 was the first 9800Pro cores, and R360 was the core in the 9800XT and "newer" 9800Pro's. At least, that's my understanding, heh.
robberbaron u r correct, but some R360 cores don't have sensor included, but 9800XT card have it. The sensor on R360 is called "National LH36 Temperature Monitor" (I think). Anyways, if he was lucky enough to have R360 core with temperature sensor supported then he's good to go. :)
Yeah its the R360 but it doesn't have a temperature sensor :( Just my two harddrives do. Rats.... Thanks anyways.
