Could someone please explain this?....
I have two HD4850s....Today I've been running each one separate on it's own (in the same top PCIE slot) and noticed a huge discrepancy between idle temps....keep in mind these cards are in the same slot, same room, same environmental conditions...
The first GPU had the following readings (average):
GPU Diode (DispIO) 46.8°C
GPU Diode (MemIO) 55.7°C
GPU Diode (Shader) 53.7°C
Now, the second one I'm currectly running:
GPU Diode (DispIO) 44.0°C
GPU Diode (MemIO) 90.0°C <----
GPU Diode (Shader) 73.2°C <----
Why the large discrepancy? It is just luck of the draw the way they come out of the factory? Some luckier cards get more accurate readings? Or should I suspect something's wrong? I just touched the sinks themselves and I'm more inclined to believe they're only as warm as the first GPU reported.
What makes even less sense is that I just finished reapplying the RAM and VRM sinks on card #2....card #1 is running cooler VRMs without even the sinks stuck on.
The only consistency between the two are the core temps.
Any explanation is appreciated!
