temp difference between cores
tyen
TAT and Core Temp both show a 2 to 4 degree fluctuating difference between core 0 and core 1.
Is this normal? (47C and 43C idle. 62C and 58C right now after running orthos a while according to TAT and 62C and 60C according to core temp)
A couple of degrees difference is normal the temperatures fluctuate anyway. If it was consistently 4 degrees hotter on one of the cores all that means is that core is doing more work than the other, still normal. Just my opinion.
