So im looking for a computer that I can do some light 3d modeling/rendering on for about a year. After a year i will likely upgrade and this build will become a render node. I would prefer an i7 920 build if possible.
3D modelling and rendering with 3ds and vray. Some photoshop and after effects. Im probably going to use it for light gaming
As cheap as possible, preferably under $800
3) Where do you live?
Toronto
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except monitors. Including all components and a case
Nothing
6) Will you be overclocking?
May want to buy a better cooler and overclock in the future but at the moment no
dual monitors 1280x800
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
no raid for firewire and i dont plan on ever using xfire or sli
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
yes 32-bit
Toronto
Nothing
Now
yes 32-bit
