dodonpachi
- Aug 7, 2012
Hi
I have this case with the build listed in my signature. I find the 180mm penetrator fan a bit intrusively loud. Plugged into my motherboard I can only have the fan set to high via the switch on the case. If I switch to low the fan just spins down.
Can anyone tell me the possible reason for this? Should I get a pwm to molex adaptor and plug it in like that to get it to spin slower? Should I just get a Noctua NF-P14s or similar quiet 140mm fan instead?
Thanks
Thanks
