Hi. I bought some Akasa Amber Ulra Quiet fans (some 120mm and 2 92mm) , so that I could replace the fans of any case that I happened to buy and since they all had 3pins , I could connect them to my Akasa fan controller aswell. The thing is I have now also bought a Silverstone Temjin TJ07 case. It cost alot of money and so it's difficult to figure out if the fans they have used are better than my Akasa's or not. I am having a tough time deciding as to which case fans to use, the stock ones or the Akasa Amber ones. Had I bought a cheap case I wouldn't really need to worry as I could be sure I was upgrading, but since this is such an expensive case, I feel kind of weird about taking of the stock fans as they could be really high qualityand much better than the Akasa ones. Please could someone help me out and give some good advice on what to do in my situation.Which fans should I use? Thanks.
