Tell Me the Settings to Overclock
set the HT link to 3x
set a 166/200 divider on the ram
and set the FSB to what you want it at (260-280)
you will prpbably have to raise the voltage of the ram and the CPU to achieve this OC if it is even possible. Just keep the CPU temps under 50C.
you should not just raise the FSB to 260 and go for it you should raise it in 2-5mhz incraments and make sure your system is stable with Prime95, OCCT or SP2004.
you might have to set a 133/200 divider on the ram depending on how well your ram will OC.
i would also recommend reading this before you do anything.
read this
