Tell me about network attached storage
InorganicMatter
We are in need of a completely new infrastructure where I work. We are running a very old-school one server per task setup on Windows 2000, and the hardware is starting to fail.
I've configured up a very nice HP ProLiant DL380 G7 systems at a low price, but they only have bays for 2.5" laptop drives. It seems for storage, they are pushing you to move to a network attached storage device.
Now I understand a bit about these. A NAS is like what you guys do, where you make a cheap box, put 8TB of drives in it, and install a lightweight Linux where there only thing that server does is serve up files. It seems a SAN is nothing more than a jumble of disks exposed, which you can then allocate to servers and connect via protocols like iSCSI.
My question is, what suits our needs? We have about 100 employees, and about 2TB of data on our current file server. A NAS almost seems too easy, and I see it as a single point of failure (which admittedly is what we have now). I'm looking at these systems and have no idea what to get. All we really need from our servers is:
Active Directory
SQL 2008
Web/SVN
Was thinking of doing one server for AD, making a Hyper-V VM for the Web server, then getting another box for the database server. Put some small fast laptop hard disks in the AD and DB servers for their boot drives (and the virtual machine images), then get some sort of NAS/SAN.
What's the best and most modern way to do this? They are willing to spend a lot of money on this, now that their old equipment is failing, so I want to make sure it's done right.
Consider two-node clustering if you don't want a single point of failure. Separating the AD and SQL servers is still a single point of failure for AD and SQL respectively.
The ideal would be to consolidate the second SQL node, the backup domain controller and the backup/mirror NAS into a single lower specs/cheaper server in a separate location for added security, but I have no idea if this is feasible or even desired.
HP seems to be right (at a cost) for you: Full choice of solutions, many specialized consultants if support and maintenance are external, reliability, etc.
Have a look at pc-pitstop.com enclosures and servers too, they're probably plenty and safe enough for your needs, and it's easier than the DIY Norco cases. You should at least compare HP solutions with others. Hell, even a 4-8 bay DAS would be plenty scalable for your current 2TB...
Sorry if this is very generic, I am no expert, hope others will answer you in more details. I subscribed to this thread to see what promises to be an interesting discussion.
