Telfon Tape !
Volkswagen
Well i jsut ordered a Logitec Wireless Duo with the MX700 mouse :) To go with that I also got my self a fUnc Black pad for $100 shipped form the egg :) Now my question is where can i buy some of that tape that go on the mouse feet and help out from wearing down the pad and the feet? Where can i order some and what do you reccomed ?
EDIT: hows www.fragware.net Mouse Tape for $1.80 for 8 inches ? Would that work?
they do but it all outa stock :mad: and the mx duo and the func pad are on the way :)
should have waited awhile and picked up the mx900 and some teflon tape.
mx700 = old :p
just go to home hardware or any hardware store and get it for 1/10 price
edit: $1.80 for 8 inches? it'll be about the same for an entire roll
That's plummers tape - it has no adhesive backing, and it's too flexible, stretchy, and fragile to be of any use.
Fragware's price is a downright bargain compared to what Everglide charges for 6".
Works fine for me, and it's sticky
It's a little flimsy, yes, if it's a problem, add 2 layers
sticky plumbers tape??? never seen the stuff. I had looked at home depot for tephlon tape and all they had was unsticky plumbers tape
