Tech Support Saying Sempron is Insufficient
Hopefully I can make the story as simple as possible:
I just got off the phone with my dad who uses three systems i've built for him. The most recent one is a Skt 754 Sempron 64 2800+ w/ half a gig of ram. The program he uses for his business is capable of networking with another system so they can both work within the same program simultaneously. Problem is it runs awfully slow on the second system. He spoke the tech support people today and they did a remote connection (which I hate btw) who told him that a Sempron is not sufficient for what he's trying to do and that they are known to not work well with the program. At the same time the second system is an older Skt A Athlon XP which the tech guy said is good.
I'm calling BS - that makes no sense that a newer, faster, sempron is incapable of hosting two systems linked within one program. Am I right or what?:confused:
Having no information on this program that you speak of I would say probably BS. If he is running a program across an internal network to another pc it could be anything. The network lag, RAM, HDD, etc. Tell him to look at his task manager and see what is being taxed when he is doing this. If he is running low on memory then it might be the memory, if the ethernet is high it may be than, etc.
Sounds to me like "tech support boy" doesn't know what a Sempron is. It's pretty rare when a CPU is the bottleneck of a system, especially if a previous generation CPU is supposedly fine for the application. I say Shenanigans.
It's a program for auto repair shops by a company called Winworks (I can't find any sys. arequirements on their site). Both systems have 512mb of RAM, which has been sufficient for a while now. The other thing the guy told my dad is that Zonealarm may be part of the problem, and he went on to 'recommend' AVG stating their company has used it for years, and blah blah blah. I've gotta go up there tomorrow so I'll kill ZA on both systems and see if that makes any difference, although I can't believe it will. My guess is that the software is at fault. I'm not terribly fond of it and it gives him errors somewhat frequently (it's a VB program...go figure). I'll check it out tomorrow and see if anything is bogging the system down, but I don't think so.
EDIT: Okuley Dokuley my dad just got home so I've got more infos.
The tech guy was saying that semprons are not good with the program, and they are not good as servers (no s#it, but serving one computer?). My dad also claimed that this guy was knowledgable and what not although what does my dad know.
See if you can get someone else (if there even is anyone else) to talk to over there that has a bit more of a clue
I wouldn't be surprised if their isn't anyone else - their tech support is ridiculous. You have to call them, and then wait to be called back if it's anything beyond easy fixes.
