TEC basics
rabidz7
When you use a a TEC in the manner of: die-shim-TEC-waterblock and the CPU wattage exceeds the TEC's capacity, does the machine imidiately overheat? Or do peltiers work by pulling the heat through and if the peltier pulls 100% of the CPU's wattage it then allows the remaining heat to diffuse naturally?
Thanks
Thanks
The heat will not diffuse. The cpu will overheat. The TEC needs to be sized in such a manner that it will remove the same amount of heat that is being produced or a greater amount than what is being produced. ** PSA A Tec is nowhere near 100% efficient.
