Hi,
I've been trying to get my two MSI Cyclone 460GTX 768 OC cards working together, but I ran out of ideas.
If I use one card in either of the PCIe x16 slots they work fine, but if there's two of them the nVidia driver has seroius issues. TDRs every now and then and besides that no SLI option in the control panel. I tried 258.96 and the two 260 series drivers, but I get exactly the same.
This is a new build, but as I said it works perfectly with one videocard. Tested with Mafia II benchmark and got the same results even if I put either card in the secondary PCIe x16 slot. Also they would be stabile after few hours.
I even got a Corsair TX950W so power is not the issue. The other specs:
Asus P8P67 Evo (BIOS 1253),
Intel i5 2500k no oc, just stock,
Corsair 4x2GB XMS3 1600 CL9 @ 1333 CL9,
Corsair F60 SSD,
3x Segate ST31000528AS HDDs, no RAID,
Cooler Master HAF 912 Plus case, with 1x20cm and 4x12cm fans, (20 (front) and 1x12 (side) in, 3x12 (back and top) out),
Razer Krait, Logitech Wave and Logitech Rumblepad II USB HIDs,
Benq V2420H display and Genius SW HF 5.1 6000 soundsystem.
All integrated peripherials disabled but Realtek HD Audio and Atheros Bluetooth. EPU and TPU disabled.
I've reinstalled win7, then MS Security Essentials, then Intel INF and Management Engine Interface drivers, then nVidia drivers, then windows updates.
Two final ideas: will check if my SLI bridge is broken, with a multimeter and try the latest MSI display drivers.
Gary_Key from ASUS is very helpful but he couldn't recreate my issue with the new motherboards and a lot of different cards in SLI.
EDIT: I've tried memtest but I wouldn't run properly:
Testing with 2 sticks only.
The + sign keeps flashing, so it's not frozen. Is it normal that there's only 2030MB detected on the picture? In windows I get 8174MB only.
I really hope someone can help!
Corsair F60 SSD,
