If a CPU has a TDP rating of, say, 91 watts, would a cooler that's rated for 170 watts be better than one that's rated for 140 watts, or does it matter?
Is there a ratio of CPU TDP vs Cooler TDP for maximum heat dissipation?
Not necessarily. Imagine the 140W cooler has 4 heatpipes and a huge fan, while the 170W cooler has 5 heatpipes and a wimpy fan. All else being equal, the 140W cooler will perform better at lower power, up until its heatpipes are overloaded.A cooler rated at 170 watts will keep the CPU cooler than the 140 watts one...
The power rating of a heatsink is affected by the non-linear thermal resistance of heatpipes. They have low thermal resistance up until a certain power, then it rises. Adding more heatpipes increases the power limit, but designs with more heapipes don't always have lower thermal resistance at a given power level. That certainly does depend on the fan, as well as the number and geometry of the fins, and various other factors.Not the case at all, if both coolers were operating at the maximum included fan speed. TDP rating ignores noise, and ignores any fan profiles the motherboard might utilize. It also ignores any alternative fans that may be used. Adding fan profiles and alternative fans into the equation is outside the scope of comparing factory provided TDP numbers.
^ That is exactly why people should use reviews to determine relative performance between available coolers. It isn't rocket science to check a few review sites and go "Oh one of these coolers I'm interested in is 5 to 8C better than the other one I was looking at."
No, cooler A & B giving similar results in similar tests on 50 sites does not mean the testing criteria is correct. And if the testing is not done properly the results have little or no meaning.You don't need a scientific breakdown of cooler performance. If cooler A performs better than cooler B four times out of four on different sites with different test methods and CPUs, cooler A is tremendously likely to be better. Then it turns into questions about size, looks, and mounting method. You can get analysis paralysis if you try breaking down simple performance numbers too much.
No everyone needs to break down questions like "What if I live in a Vietnamese jungle" and "What if my case is only 3L and has close to zero airflow".
