Tbred capable PC133 mobo?
All the PC133 boards that "claimed" to support T-bred processors were flaky at best. I never had any luck personally. Tbird 1.4GHz is the highest you can reliably go... otherwise it's hit and miss.
ECS K7S5A supports PC133 and PC2100 and it's dirt cheap.
I have used Tbred A, B and Bartons in one with no issues.
ECS K7S5A like was mentioned is a cheap solution I have one of these and one of the pro version as well. They are reliable and I havent had any issues with either of them I have brand new Pro version still in the box usused
ive got an asus a7v133 that works with sdram and supports up to an xp2100 (palo core) although i might get rid of it because i just made a deal for a pIII-s 1.266ghz chip and MSI board... so if your willing to wait, you might have a board from me...
edit: crap, i was thinking about Tbird my bad. the board i have doesnt support a tbred at all.
a7v133 just works with Tbred from revision 1.02. (with the dot after 2) on. Any PCB older than that doesn't support it.
not according to asus's website it dont. i have rev 1.05 and it supports tbirds and palo's according to asus.
My A7V133 is working fine with my 1700 Tbred. I'll check the revision if you want.
There were some KT266 boards that had both DDR and PC133 SDRAM slots. One was the Shuttle AK32A. I got one for some friends who fried an older Soyo board, but were on a tight budget, and needed to be able to use their present memory.
yeah, tell me if you could.. id love to slap a tbred in there, theyre much cheaper than palo's now..
It's a Rev. 1.05. Limited VDIMM is what I think holds the FSB back. I was able to run my KT7A to a little over 150 FSB (3.6 VDIMM), but I've never been able to get much over 140 out of this motherboard reliably. I'm using a beta BIOS from Asus. The multiplier only goes to 12.5. I believe there is a wire trick to get higher multipliers, but I've never bothered to find out (it's my backup system).
im gonna go grab my mom's 2000+ and give it a shot..
holy crap, it posted
what it wont do, however, is post at 133x12.5 :(
edit.. 3? it does! i had the switches on the dipswitch reversed, lol
i wonder if it would go for a barton..hmmm...nevermind, just rembered a barton would need a 166 bus... unless its a mobile.. but that would be a waste of money..
All right, it worked! I've found that CPU support is very conservatively rated by the manufacturers. The better Socket A boards will often surprise you. And in a case where a CPU may work, but may not, they'll say it won't just to avoid tech support issues on a product that has aged past being updated. Abit says that nothing earlier than the last of the KT7As will support a Palomino. But most who tried an XP found that it would work with no problems, or at worst need an occasional reset on boot. I set my cousin up with a KT7E and a 1600 Palomino. It shouldn't have worked per Abit, but it has been very reliable.
But Tbreds run at lower voltage, so it's a little different than with a Palomino. As I'm giving this system to my brother, I'd rather it be at default voltage and not overclocked.
Also, some of the older boards may not support the higher multiplier for a 2400+.
